code 1283
  • CavemanGB
    • Sep 2019
    • 31
    code 1283
    I am getting code 1283 Fuel Injector Output Stage on my car. I double checked the wiring and all the connections look fine. I just bought another DME but is there anything else I should be checking? I couldnt really find any info on the code anywhere on the site.
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5597
    Check the connector underneath the intake.
    It's for the injector harness and both coolant temp sensors
    edit: My bad I thought this was the m20 sub
    Does the car run fine? Missing??
    • CavemanGB
      • Sep 2019
      • 31
      So it will start fine but idles high (1k warmed up) and sometimes if I rev it, it wont drop down back to 1k until I push the TB to close. When this happens after reving its usually comes down to about 1500rpm.
      My replacement DME comes in today so Im hoping I can get out there and swap them to see if that helps.
      No other codes are popping up.
      • CavemanGB
        • Sep 2019
        • 31
        Swapped in another DME and it works great now!
        Is there a service that refurbishes DMEs? Thinking I might want that done to the original one.
