2009 24v Swap Registry
  • OrganicMechanic
    • Jan 2008
    • 1719
    For those who swapped in the year 2009.
    what you put in-
    any issues-
    whatever you care to disclose.
    join the E30 Cabrio owners gruppe
    click here for details
  • OrganicMechanic
    • Jan 2008
    • 1719
    m50
    O2 sensor issue initially, fixed with a relay in the adapter harness between 13-13 pins.
    Looking forward to putting this on next winter
    • rThor432
      • Feb 2007
      • 3907
      what you put in- M70B50
      any issues- No.
      whatever you care to disclose- I'm lying.
      • dude8383
        • Jan 2005
        • 10387
        M50B25
        M52 Pistons 84.5mm
        M52 Crank
        S50 Cams
        Fully rebuilt M50
        Issues: Needs a tune, but need to sort out oil leak and a few other minor things before that is done.
        • PiercedE30
          • Apr 2005
          • 4220
          what you put in- M50B29
          any issues- Couldn't get a tune for an 11.5:1 NV motor due to lack of knock sensors, decided to install knock sensors and run MS2/Extra. Runs great, little bit of wandering idle at times due to PWM control issues that I haven't really cared about enough to tune out.
          Made 230 ft/lbs of torque with dual NV intake cams. Currently running NV intake and S50 exhaust (reground NV exhaust cam to S50 specs).
          My 2.9L Build!
          • tonytony
            Knee deep in poopie
            • Jan 2004
            • 3498
            why is this just for the 2009ers? what about us pre9ers
            • PiercedE30
              • Apr 2005
              • 4220
              Oh, my bad. I finished my swap in January of 2008.
              My 2.9L Build!
              • tonytony
                Knee deep in poopie
                • Jan 2004
                • 3498
                ^yeah dood, you fucked up......
                • RedHoodRidah
                  • Feb 2006
                  • 1096
                  Started early January-Completed swap mid-February
                  -M50B25
                  - Leaking PS fluid from one of the lines. :)
                  - Pretty good with a Getrag 240 and 4.10 rear. Seems to be pretty fun so far. Daily driven since the swap put about 3kmiles on it since with no major issues since day 1 and plan on keeping it that way.
                  M42 was taking up engine bay space so it had to find a way out and it decided to lose compression.
                  92 Granite Silver Vert
                  M60B40 5spd
                  • shiboujin
                    • Feb 2006
                    • 2791
                    What about me? I started mine last july and drove it around the block literally today.
                    • xLegendOZWest
                      • Jan 2009
                      • 406
                      put in: M50B25 (nv)
                      issues still don't know what to wire the o2 sensor into. (i swear it was never there)
                      260 trans with 3.91 rear end. needs exhaust so so so bad!
                      Live Fast. Drive Faster.
                      "Nitrous is like a hot girl with an STD... :)
                      You wanna hit it, but your afraid of the consequences :(
                      • 318isbmw
                        • Nov 2005
                        • 2841
                        +1 We got 7 months left in the year before 2009 is over w/.
                        • Mohammed_A
                          • 344
                          what you put in - S50B32
                          Issues - gertrag tranny that i put in was stuffed, had to replace with ///M3 tranny, still have a surging problem and rough idle.
                          Still needs a tune and an engine wash
                          • SamE30e
                            • Sep 2007
                            • 4319
                            M50 Non-Vanos into my 91 318is.
                            Issues - Constantly hunting for an idle but hopefully fixed with a new exhaust.
                            And oil filter stand leak.
                            Shifter selector rod from a E36 doesn't work with the G240, just shortened my M42 rod.
                            Time to complete - 2 months taking my time dicking around.
                            1985 325e 2.8 Turbo VEMS
                            • z31maniac
                              • 17566
                              I'll be putting in an OBD-I S52B32, 3.5 MAF, BW intake boot, maybe do a BBTB, eBay SS headers, 2.5" single exhaust.
                              Issues: Need more monies to finish.
                              www.gutenparts.com
