Help to identify cables´.
  • Swebimmer
    • 3
    Hi iam on to doing my m50 swap but i need some help to know were to connect these cables
    Question1: Where schould i connect this one? put a battery shoe on it and
    connect to +?
    Question 2: And these two were do i connect them?
    Question 3: Is these apart from starter cable and the round plug all i need to connect to get it running?
  • jrdeamicis
    • Nov 2008
    • 956
    The top one used to go to the E36 Fusebox for body power. Tape it and hide it. I hid mine in the covering.
    The bottom two I bet are ground a power. Pull back the covering.
    Past Car : E30 S50 6 Speed 5 Lug 3.73
    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
    ___________________________________________
    BNB Designs
    Engine Swaps, Fabrication, Innovation, General Repair
    Richmond CA
    Julian 848-248-8029
    • Swebimmer
      • 3
      Ok thanks the engine is from a e34 but if i tape that cable i only have one power and ground to connect it feels like it should be moore. And i dont have a battery shoe on any cables
      • mbonder
        • 2255
        Should just be a positive battery connection coming from the starter, that's it. The negative terminal is just grounded to the frame.
        • RedTRex
          • Dec 2008
          • 249
          there needs to be a power cable from battery to fuse box, either the original e30 one (seperate from m20 harness) or the M5x one which is in the harness.....
          for your question 2 for my m50 one is a ground the other is the batt connection, other end of wire from your pic 1.
          Leave now before I shed my human form and kill you
          • Swebimmer
            • 3
            Ok thanks! if i pull back the covering on the two black cables how can i tell wich is + And -?
            • etxxz
              • Feb 2006
              • 2085
              i can almost guarantee both are grounds (strut grounds)
              pull/cut insulation. If brown = ground. If red = +12v. they won't be any other color.
              No more e30s for me.
              88 black BMW OBDII 332is dedicated track [sold]
              88 BMW OBDII bronzit 332is [RIP 03/08]
              91 BMW 325i [sold]
              86 Corolla 'Ae86' HB 20v trd [sold]
              http://youtube.com/watch?v=pTj7Hn9v5Rs
