obd1 coils on obd2 manifold... dont fit?
  • lifeiskaos
    • 1709
    what's the secret? there are little tabs that seem to be in the way. i knew i'd have to use a dremel for the wiring, but can someone enlighten me?
    oops... i meant valve cover
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    I just noticed this as of late while throwing all my m50/m52 stuff together. I'd like to know as well.
    • M-technik-3
      • 18946
      Why not just use a M50/S50 valve cover?
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Because the plastic m52 unit looks much better.
        • lifeiskaos
          • 1709
          plus a hundred
          • e30serg
            • Dec 2006
            • 562
            The valve cover has to match the coils.
            • lifeiskaos
              • 1709
              i'm 95% sure some people use obd1 coils with an obd2 valve cover.
              • e30serg
                • Dec 2006
                • 562
                Really? I'm thinking the opposite. I can't really check since I don't have OBDI coils. I do have both covers though. I can't remember correctly now.
                • rThor432
                  • Feb 2007
                  • 3907
                  Why not just keep the OBD-II coils? Or do you not have them..? It might be related more to the age of the coils than anything, but I see a ton of the OBD-I coils fail. Havent seen near as many OBD-II coils fail, they seem to be better anyway.
                  I have the OBD-I harness with an OBD-II valve cover, coils, and vanity cover. I had to trim the vanity cover a bit to clear the coil wires.
                  • lifeiskaos
                    • 1709
                    ohh ok, i thought coils had to match the harness. damnit.
                    FS: 6 obd1 coils
                    WTB: 6 obd2 coils
                    who wants to trade?
                    • z31maniac
                      • 17566
                      Precisely what I plan to do.
                      www.gutenparts.com
                      • bwh13
                        • Jan 2007
                        • 437
                        The coils have a different stagger to the holes, found this out when I switched covers and only had 5 OBD1 coils to use. I did manage to use 1 OBD2 coil until I decided to put the OBD2 cover back on...
