quick sensor question
  • dele30
    • 116
    I know that this has been covered many many times, i have looked and i know that it is the brown top sensor from the m20 is the one that is swaped to the m50. online i cant seem to find the brown top, only one i could find that i think is the same one is this http://www.rmeuropean.com/Part-Numbe..._10832E0B.aspx
    can someone confirm that it will work for the cluster temp sensor for a m50 swap. thanks!
  • dele30
    • 116
    or this one, i need to order this really soon, please help asap!
    • mazur
      • Jan 2006
      • 731
      That one does not look right at all. Besides, it won't ewven work with the OEM connector of your M50 harness.
      Check realoem.com. Remember, this is the sensor for the coolant temp gauge in the cluster.
      Edit: Here you go. http://www.realoem.com/bmw/showparts...59&hg=11&fg=35
