No Fuel
    No Fuel
    OBD1 M52
    Car was driving fine, went to start it and no go...
    Checked spark, its there
    popped off the fuel feed line, cranked it over and nothing
    I connected 87 to 30 on the fuel relay near the driver side shock tower and still nothing
    Is there a way to test my pump, or is this an obvious pump failure?
    Thanks to anyone who can help
    Evan
    Make sure your pump is still plugged in. I had an issue where my connector at the pump was loose and would disconnect itself. If it is still connected check for continuity between it and the fuse or just jump ground and power directly to the pump to see if it runs.
      Just checked it with the multi meter, Im getting power to the purple/brown and to the green/brown when the key is turned, but cant hear any action with the pump
      So im assuming my pump is shot...
        Should i go with the bosch one, $223
        or the tre high pressure for $120
        Anyone have experience with the tre?
