Coolant temp sensor
  • 325issguy
    • Dec 2005
    • 261
    Coolant temp sensor
    Hey guys,
    I just bought an 1987 325is with a 98 m52 swapped into it.
    My car has a m3 dash. I cannot for the life of me get the coolant temp gauge to work. I have tried the stock m3 temp sensor and it has not worked even when i switched the plug around... Anyone have any tips? I have checked the wiring, it works fine.
    My oil temp gauge does not work either. The previous owner said that it has a 88 oil temp sensor but I have not confirmed it.
  • Uber E30
    • 1409
    where did they put the sensor?
    -Alex
    • 325issguy
      • Dec 2005
      • 261
      I have this part.
      It is installed as shown, there is coolant in there every time I remove it to change sensor, etc. I just dont get why it doesnt work. Do I need to ground the actual part or should it just ground from screwing in?
      • FredK
        • 14747
        I'm pretty sure you need to run a separate ground from the $49 manifold to somewhere on the block/head.
        • 325issguy
          • Dec 2005
          • 261
          How did you all run the ground?
          • FredK
            • 14747
            There is a screw on the machined piece. Crimp a ring terminal to both sides of a wire. Attach one side to the machined piece. Attach the other to the front of the valve cover, where the fuel rail ground attaches.
            • 325issguy
              • Dec 2005
              • 261
              Thanks guys,
              I dont remember seeing a screw but I will double check. I tested a ground on it tonight and that was my problem.
              -Chris
              • almostM
                • 376
                Can I get more info on your M52 swap? Or other M52 swaps
                • e30devo
                  • Aug 2005
                  • 1102
                  haha.
                  • z31maniac
                    • 17566
                    Search.
                    You can find the answer to just about every question you could possibly have on 24v swaps without starting a single, new thread.
                    www.gutenparts.com
                    • 325issguy
                      • Dec 2005
                      • 261
                      Just for clarification, my sensor manifold had no screw in it. I just ran a clamp around it for the necessary ground. Works like a charm. Now for the oil temp gauge haha.
