I'm swapping my s50 for an s52 OBDI -- got a killer deal on an s52 that I couldn't pass up. Low miles, from an automatic car, etc.
Anyway, I've tapped the s52 head and threaded it for the proper coolant sensor and I will be using the same OBDI harness from my s50 motor.
Which coil packs should I be using? Can I keep the OBDII coil packs from the S52 on the motor? Tuners sell OBDI or OBDII coil packs, since I'll be using an OBDI harness do I need OBDI coils?
Thanks
Thanks
