reuse flywheel bolts?
    I am ordering some parts for my m50 to s52 switch and was wondering if i should get new flywheel and pressure plate bolts. I had replaced them when i put the m50 in but can i just reuse them?
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    You can reuse the bolts, but ideally you want to replace them because of the thread sealant that comes on them when they are new. You can reuse the old bolts with green or blue Loctite.
      No, they stretch. You can NOT re-use them.
      Past Car : E30 S50 6 Speed 5 Lug 3.73
      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
      ___________________________________________
      BNB Designs
      Engine Swaps, Fabrication, Innovation, General Repair
      Richmond CA
      Julian 848-248-8029
        Same with main bolts, head bolts, and a few other ones.
        BNB Designs
        Richmond CA
        Julian 848-248-8029
          those things are on there so tight... i think that reusing them would be a really bad idea. they can't be that much money.. are they?
          Greg
            They are not that bad. For being THAT important. They are cheap.
            BNB Designs
            Richmond CA
            Julian 848-248-8029
              yeah, that's what i figured. I haven't ever done a flywheel, but i pulled one off of my old motor two days ago... 24'' pipe on my wrench and it still took my whole body to move them.
              Greg
                They are torqued in the 80 range if I remember correctly. There is a lot of heat and stress down there.
                BNB Designs
                Richmond CA
                Julian 848-248-8029
                  If I was using the Getrag 260 and clutch + flywheel with my S50 swap, I would use the S50 flywheel bolts correct?
                  My previous build (currently E30-less)
                  http://www.r3vlimited.com/board/showthread.php?t=170390
                  A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                    They can be reused, but they are cheap enough to replace them. The only thing in a motor that under no circumstances I would reuse are rod bolts.
                    And they TTY (torque to yield) type bolts. TTY bolt have a specified angle to torque to not a torque value....Therefore they can be reused.
