s52 pistons in a s50 block
  • zav3n
    Curious George!
    • Mar 2007
    • 223
    s52 pistons in a s50 block(stock rods) will it work? compression ratio? anyone try it?
    thanks
    -zaven
  • e30this
    • 3580
    Search it up, Its been done. If you say your cant find any info then your lieing and you didnt search hard enough.
    • zav3n
      Curious George!
      • Mar 2007
      • 223
      sry bout the wrong section admin plz change,
      .. thats the first thing i did. anyway i found:
      http://forums.bimmerforums.com/forum.../t-267488.html
      plus i dont want to bore out my block and then find out that it wont work...
      • jflip2002
        • Sep 2006
        • 4377
        Im not the most mechanically inclined person on this site, by any means. But if you dont want to alter the block at all, what makes you think pistons from a motor with a greater displacement would work properly?
        Originally posted by blunt
          • 37829
          I would recommend checking the tolerances on the Sevan to boost clearance.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
            • 37829
            PS: Good luck.
            Grover Beach, CA
            www.BimmerHeads.com
