24v Swap.. awnsers i havent found yet.
  • MattM
    • Apr 2009
    • 931
    I am dropping an M50 from an E34 525I into my ETA 84 325 e, and have done a fair bit of reading and have afew last question.
    1. with the getrag 260, what do i do with the 2 sensors comming off it, on the M20 there are ports for them to plug in, but none to be found on the M50.
    2. how do i mount the late style expansion tank?
    3. can i use the sheet metal shifter carrier that was in my car?
    4. do i need to bend new brake lines? the IX booster doesnt seem to want to go in without bending the brake lines?
    im sure i will have more Q's as a proceed.
    Full Build Thread Here
  • BigD
    • Jul 2006
    • 1085
    Find or buy the plastic bracket that screws onto the fender, the tank just snaps into it (the bracket screws into the fender with a sheet metal screw). ORCA has measurements for where it should go, but you can eyeball it by just putting the tank on the fender. There's a metal loop that goes on the bottom, and there's a tongue on the bottom end of the tank that slides into the loop. I made my own and riveted it on, I know some guys just leave it off - the plastic bracket and the hose supports it pretty well.
    I didn't have a problem with the booster but I had to bend the lines to reach the MC. I also don't have ABS so I had to get a T and bend another line to get the front/rear bias right (I bought the OEM T for the rear junction).
    • MattM
      • Apr 2009
      • 931
      thanks, i dont have ABS either, so i guess i will need that T peice aswell. and i will just play with it abit more...
      i found the little clip for the expansion tank, it was like 1.50 so i ordered it...
      • FredK
        • 14761
        These are engine reference and speed sensors for the M20 Motronic. You will not need these sensors for the M50.
        • Van Westervelt
          • 9365
          3. You can use that metal plate shift carrier, you cant really bend it as well as you can the late model one. So it is a bit of a pita to get your shifter anywhere close to center on the topside. But you can use it nonetheless.
          • MattM
            • Apr 2009
            • 931
            is there plugs i can buy for the sensor holes on the transmission? if so what are there part numbers and/or where can i buy?
            • matt
              • 3731
              21 11 1 225 047 x2
              • MattM
                • Apr 2009
                • 931
                alright, now for tranny mounts, do i use the 320I green or grey mounts?
                #2 in this pic?
                or #2 in this one?
                Also, for mounting the late rad in an early car, what else do i need in this diagram?
                i figure 6,7,8,9,10, do i need 12, 15 and 16? i am using the mechanical fan from the M20
                • matt
                  • 3731
                  Green Trans mounts. You need #9, #11, and some zip ties.
                  • MattM
                    • Apr 2009
                    • 931
                    thanks guys. ill order up those parts:)
