s52 obdI maf or euro 540 maf...
  • jakeb
    • 1909
    I am about to order a TRM chip for my obdI s52 that I plan to swap over next week from my m50. Debating going with the OBDI maf that I already having or picking up the 3.5" maf and getting a chip to match. I really do not want to go up to 24lb injectors as I have heard it is overkill unless it sees the track a lot, which my car will not.
    So...is there a huge gain with the 3.5" maf over the obdI 3" maf? Also with the 3.5 do I need to get a different neck that goes from the MAF to the throttle body?
    I want to order the chip ASAP,
    jake
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • matt
    • 3732
    If it's an M50, I would save the money. Stock MAF and injectors are fine up to S50 power levels, or more.
    • jakeb
      • 1909
      no it is a s52... switching from a M50 to the S52
      • matt
        • 3732
        Hmm, I guess if I had read the first half of that line I would know that.
        I guess I would probably go for the euro MAF for an S52.
        • rThor432
          • Feb 2007
          • 3907
          I didnt have mine tuned when I had the stock MAF, so I cant compare. But my OBD1 S52 with the big MAF and the TRM chip is excellent. For what it's worth, I'd say go for the big one while you are upgrading the car.
          • jakeb
            • 1909
            yeah i am going to go that route. Are you running the 21.5lb injectors or 24 thor?
            • matt
              • 3732
              A stock S52 does not need the larger injectors and will not benefit from them at all.
              • rThor432
                • Feb 2007
                • 3907
                ^^I'm running the 21.5 lb pink injectors.
                My opinion-- I just see it as wasted fuel. There is room in the software to make better use of the stock injectors, so rather than dump more fuel, use software as the answer. A lot of people talk them up, but I dont see enough of a benefit.
                Just drove my car for the first time in a week (I've been out of town). It drives so nice.... Get the MAF and finish her up! :)
                • sushipower
                  • Aug 2005
                  • 156
                  I have S52 with 540 MAF, but I am using 24lbs. Works good and I get around 18mpg when not fooling around.
                  • rThor432
                    • Feb 2007
                    • 3907
                    Wow. Just to toss it out there, I average 30. All highway I do 33 mpg.
                    • sushipower
                      • Aug 2005
                      • 156
                      Ouch! That's pretty good MPG for an S52. My stock m20 is getting 18 mpg.
