Confirm my suspission...engine dies
  • Beej '86 325es
    • 2639
    I picked 'er up from the exhaust shop this week. It ran fine when I dropped it off, but when I picked it up, I couldn't keep it running for more than 15 seconds, having to give it a lot of gas to keep it running even for that long. Each time I restarted it, it would run for shorter and shorter periods. By the end, it would only fire a couple of cylinders.
    I'm thinking it's got to be fuel delivery related. Could a bad fuel pump relay cause this?
    Thanks
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
  • lifeiskaos
    • 1709
    lol. sounds like when i blew the pistons rings in my m20 turbo
    • Uber E30
      • 1409
      i bet they fucked up your O2 sensor
      -Alex
      • M-technik-3
        • 18946
        Try disconnecting the o2 sensor.
        • Beej '86 325es
          • 2639
          Actually the O2 sensor still hasn't been hooked up. That was a nice little surprise when they forgot to do that portion of the work.
          -Brandon
          '86 325es S50
          For sale:
          • sushipower
            • Aug 2005
            • 156
            Sounds like it's your fuel pump. Can you hear it when cranking engine? Take off your fuel line at fuel rail and give it a quick crank. GL
            • BigD
              • Jul 2006
              • 1085
              I dunno guys giving more gas shouldn't keep a car with low fuel pressure running - it should make it die faster. If the pump can't supply enough fuel at idle, it surely won't be able to supply at more throttle (air).
              At best I'd guess it's a vacuum leak that's getting worse, like a loose ICV hose, which is slowly falling out more and more. That way I could see more throttle making it run longer when the leak isn't too bad - the unmetered air would make it effectively less lean at more throttle.
              What follows is a bit of fear mongering so you may want to choose to not continue reading...
              What you describe is how my S38 died when the chain skipped due to a dying oil pump (the chain tensioner on those is hydraulic). First it started running weak, but giving more gas made it almost fine. Then it was less and less powerful, then it was hard to start and didn't run for long, and finally it wouldn't start. Like you I thought it was a dying fuel pump or something so I kept trying...
              • SamE30e
                • Sep 2007
                • 4319
                Maybe they didn't unplug the ground when they welded.
                1985 325e 2.8 Turbo VEMS
                • Beej '86 325es
                  • 2639
                  I'll check if the pump is running tonight.
                  I think they did, because the negative battery terminal was loose when I picked it up.
                  -Brandon
                  '86 325es S50
                  For sale:
                  • Beej '86 325es
                    • 2639
                    Replaced fuel pump relay, no avail.
                    Checked for spark, all good. I can smell fuel out the tailpipes though.
                    I THINK the fuel pump is pumping. Tomorrow I'll try checking for fuel pressure at the rail...running on 3 hours sleep today from the Aerosmith concert! :(
                    -Brandon
                    '86 325es S50
                    For sale:
                    • M-technik-3
                      • 18946
                      OT but how are the old guys performing these days?
                      • Beej '86 325es
                        • 2639
                        pretty good actually, they still get the crowd going. Unfortunately they played mostly new songs that nobody knew. It was at an outdoor amphitheater and we had some severe storms in the area. They delayed the concert until about 11, and then we stood in the rain for another couple of hours...
                        -Brandon
                        '86 325es S50
                        For sale:
                        • 416stroker
                          • May 2008
                          • 2448
                          Coilpacks everything I've heard they just can fail one after another
                          84 318I Delphin RIP
                          87 325IS delphin 24v Sold
                          89 325 Alpineweiss
                          • surebimmer
                            • Jan 2004
                            • 978
                            Make sure the ICV tube is locked into the manifold. When I started my car it backfired through the intake and blew out the ICV hose under the intake and the car would start and run like crap, large vacuum leak. Locked the ICV hose back in place after i found it and run's great.
                            • Beej '86 325es
                              • 2639
                              Thanks, I'll check tonight
                              -Brandon
                              '86 325es S50
                              For sale:
