S50 E30 swap - Differential Question
  • USSR2K
    • 3
    #31
    I work part time at a local salvage yard. I came across a 1992 convertible with a 4.10 slip differential. I am willing to trade this for something that is quite and fits my 1986 325 E
    • richardb
      • 2121
      #32
      So I don't get bashed for starting a new thread...
      I have a nvm50 with g240 trans, and small case 4.10lsd HORRIBLE on the highway. I drive highway 90% of the time. Will be doing a turbo setup next spring... I am thinking 3.25 lsd... yes? I would like to be between 3000 and 3300 rpms going 80. I travel 80 on the highway in good conditions, 70 in light traffic and probably 60 in heavy traffic on I95.
      SO any advice for the best option?
      Transaction Feedback!
      • Uber E30
        • 1409
        #33
        3.25 or 3.46 for turbo
        -Alex
        • e30polak
          • 6136
          #34
          Or 2.93. It depends on the size of the turbo. If the OP is going for a bigger turbo then I'd say 3.25 or 3.46. If it's a small turbo that will spool quick, then you will want a longer power band before the turbo chokes, i.e 2.93
          INSTAGRAM: @UNDR8D_EMPIRE
          • Wh33lhop
            • 11705
            #35
            I'm also thinking of going a little longer when I get the car back together (M50NV), thinking maybe a 3.46 for the G260 in there. I like the stock short gearing for dicking around, but without a 6th gear on the highway 3500rpm at 80 gets kind of old, and I'd like first to be a bit longer, maybe reach 37-38mph instead of 30 flat.
            Has anyone run an M50 and a G260 with a 3.46 or a 3.25? I don't want stupid high eta gearing or anything, but just curious to read people's impressions.
            paint sucks
            • FredK
              • 14752
              #36
              I have a pretty loud exhaust, a ZF320, slightly undersized tires, and a 3.46. I drove to NJ and back with no radio a couple weeks ago. It wasn't that bad.
              • 5KWattson
                • Apr 2009
                • 809
                #37
                that gearing calculator, i just scrolled over it but how would i fig a 4:10 with a Gatrag 260 an a m50tu rpm at 80 mph
                "God created turbo lag to give V8's a chance" Taylor D.
                • D-rock
                  • 714
                  #38
                  I had the 2.93 in my car and the gears were sooooo long i really liked it. On the 3.25 i was in 5th doing 75 at 4k and couldnt get anymore out of the car so i really dont know.. :/
                  • 5KWattson
                    • Apr 2009
                    • 809
                    #39
                    damn i have a feelin its guna suck ass for freeway and i drive like 13 miles to work every day...FML...oh the reason i say im have a feelin is with my m20 my cluster never worked so i didnt even know the rpm difference between the 3:73 and the 4:10, but the M50 is goin in really soon so i need to get another one
                    • D-rock
                      • 714
                      #40
                      I feel like the 2.93 is the way to go! there is not that much of a difference. Between 3.25,3.46
                      • e30polak
                        • 6136
                        #41
                        Wrong! :hitler:
                        The 3.46 is definitely a nice jump from a 3.25. The moment I drove it at first, it felt like I got another 20lbs of torque throughout the powerband! :-D
                        I want to try out a 2.93, since it would make 1st and 2nd longer.
                        • Wh33lhop
                          • 11705
                          #42
                          With a 4.10 and a G260 you'll be at about 3700rpm at an indicated 80mph.
                          Sorry but even with a 1:1 5th gear and a 3.25 you're not turning over 4000rpm at 75mph. A ZF/G250 with a 1:1 and a 3.25 will be about the same as a G260 and a 4.10: 80mph at about 3700rpm. If you're doing 4k at 75mph and you're running an E36 gearbox, you've got a 3.73.
                          The difference between a 3.46 and a 3.25 is about 65% that of the difference between a 3.25 and a 2.93. So, is it as noticeable as the change from 2.93 to 3.25? Not quite, but it'll be in the same ballpark.
                          paint sucks
                          • D-rock
                            • 714
                            #43
                            Now what will give you a bit longer gears a 3.25 or 3.46. I feel like I might go back to the 2.93. Of the line it was a bit slow. But on the high way it was very nice!
                            • e30polak
                              • 6136
                              #44
                              Sounds about right. A 3.73 with a ZF cranks 80 at something like 4500. I used to run 75 @ 3100 with 215/45/17 which were a little over-sized, when I had the 3.25.
                              • Uber E30
                                • 1409
                                #45
                                Uh, sorry but you're wrong.
                                4.10 on a g260
                                3.25 on a ZF
                                -Alex
