Which Hose?
  • Mohammed_A
    • 344
    Which Hose?
    Im busy installing a temp switch to activate my electric fans for cooling, was wondering which pipe should i fit the switch in? i have a 84 deg switch, is it better on the top radiator hose on the left or the bottom one on the right...
    Please help
  • gobuffs
    • Dec 2004
    • 513
    upper right top of radiator, not in either hose.
    • sharksforthecup
      • Aug 2007
      • 246
      Please help
      Wow I'm really going to have to hammer this point in.
      USE THE REALOEM.COM DIAGRAMS!
      like this one, where #11 has nothing to do with a hose.
      http://www.realoem.com/bmw/showparts...02&hg=17&fg=05
      • Mohammed_A
        • 344
        i have one in the side of the radiator, its a 92 deg switch, it was standard so when the car tends to heat up past the half mark then it would activate the 2nd speed of the air con fan...... im leaving that as is as a safety precaution...
        because im no longer using a viscous fan i need another type of cooling to keep the engine temp in check, im using 2 10 inch electric fans.... thats why i need to get into the pipe...
