My few s50 questions
  • e30_325es
    • 1249
    I've got an ltw flywheel, a clutch disc, and now I'm looking for a pressure plate. I see a stock one and a sport one. My s50 should be around 250whp, should I opt for the higher clamping power pressure plate or will the stock one suffice?
    If I put the smaller output flange on my zf trans, will I be able to use my stock driveshaft? (86 eta)
    I'll update this as I have more questions, but I think these are my only ones. Thanks!
  • jahnaboi
    • Oct 2006
    • 1742
    1) Stock should be fine
    2) What's the build date? If higher than 9/86 then you have the 96mm guibo which will not work with the smaller output flange. If you have lower than 9/86 you should be fine. Unless you use the front half of a 325i driveshaft with your smaller output flange, you could run that.
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
    • e30_325es
      • 1249
      Thanks on the pp info, and with the driveshaft, as long as I have the proper sized output flange, I'll be ok? Meaning the length makes no difference?
      • e30_325es
        • 1249
        Ok, so, I've got a small guibo output shaft flange. The splines are different than my 5/96 build zf trans. Which it seems means that I now have to return my new driveshaft and get the proper one for the large flange. Unless anyone has any ideas?
        • jrdeamicis
          • Nov 2008
          • 956
          Couldnt you use the front section of a small flange car mounted to your rear half of your drive shaft and get it re-balanced.
          Past Car : E30 S50 6 Speed 5 Lug 3.73
          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
          ___________________________________________
          BNB Designs
          Engine Swaps, Fabrication, Innovation, General Repair
          Richmond CA
          Julian 848-248-8029
            • 37829
            Your Eta driveshaft is the wrong length anyway.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • e30_325es
              • 1249
              Gd it. So what driveshaft do I use? Late eta with large bolt spacing, e30 m3, or e36 328i?
              • e30_325es
                • 1249
                I got a 328i driveshaft now. Do you or do you not have to reverse the csb? I'm reading conflicting info here.
                • rThor432
                  • Feb 2007
                  • 3907
                  ^^From what I understand, you just use the E30 CSB on the E36 shaft.
                  • e30_325es
                    • 1249
                    I've got that much figured out. I just need to know which way to install it. Just like stock or like the 328 one?
