IX booster and master cylinder options
  • jrdeamicis
    • Nov 2008
    • 956
    So the 95 M3 Master cylinder will bolt to the IX booster. However with a 24V it is too long and will hit the intake even with the spacer removed. Also the brake lines are the same size. But it is an idea and good to know.
    The MC for the m3 is a 25.4
    Past Car : E30 S50 6 Speed 5 Lug 3.73
    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
    ___________________________________________
    BNB Designs
    Engine Swaps, Fabrication, Innovation, General Repair
    Richmond CA
    Julian 848-248-8029
  • jrdeamicis
    • Nov 2008
    • 956
    I also checked rod depth. Its really small gap before the rod hits the MC.
    BNB Designs
    Richmond CA
    Julian 848-248-8029
    • aivaras325
      • 7
      I bought Reno Clio break booster ( http://en.wikipedia.org/wiki/Renault_Clio - first gen one). Gap between intake manifold and break booster is more then 1cm (using E28 535 engine mounts), the four bolts and E30 master cilinder fit. The rod had to be increased by about 16mm and the pin hole drilled to 10mm from 8mm. I havent put it yet so no idea about preformance...
      • etxxz
        • Feb 2006
        • 2085
        the MC cyl hits the intake hose or the brake resevoir? i'm using a MC off an e34. the e36 one seemed to be equal in size. i have an IX booster with no spacer on the back. check this pic:
        that's my old chasis it all cleared just fine. tight, but clear.
        No more e30s for me.
        88 black BMW OBDII 332is dedicated track [sold]
        88 BMW OBDII bronzit 332is [RIP 03/08]
        91 BMW 325i [sold]
        86 Corolla 'Ae86' HB 20v trd [sold]
        http://youtube.com/watch?v=pTj7Hn9v5Rs
          • 37833
          You need a remote reservoir.
          Grover Beach, California
          BimmerHeads.com
          • jrdeamicis
            • Nov 2008
            • 956
            I dont have the intake in atm since its impossible to mount that BB with the intake in.
            But my guess would be that the actual MC hits the boot. I am going to try it. Proper brake proportioning for my setup is what I am really going for.
            I will get more pics next week.
            I plan on cutting the extender out of the spacer and welding the stack together onto the BB
            BNB Designs
            Richmond CA
            Julian 848-248-8029
