OBD 1 harness auto to manual conversion
  • kevmo707
    • 62
    I recently bought a bunch of obd1 parts and i thought the harness was from a manual car but it is from an auto and i was wondering how to convert it???
  • BMW_TUNER
    • Jul 2006
    • 1386
    I just did this and it was not that hard. just carefully remove the auto plug and the plug for the auto brain and make sure you connect the brown/black wire pin 26 transmission ECU” need to be connected to any “red/white wire on the main relay.
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
    • xLegendOZWest
      • Jan 2009
      • 406
      what happens if you dont connect the brn black? ive been driving for like 6mo without it
      = o
      Live Fast. Drive Faster.
      "Nitrous is like a hot girl with an STD... :)
      You wanna hit it, but your afraid of the consequences :(
      • e30this
        • 3580
        You dont need to do anything, Just let it alone and it will work just fine the way it is.
