How hard is it to install a 6 speed tranny?
    I have a 6 speed E36 tranny available.
    What are the main problems in doing such a project? Do I have to physically modify the 'tranny tunnel'?
    Do I have to fabricate a special tranny support bracket or do I use the E36 one? WHat about tranny mounts? What driveshaft?
    Thanks!
    KEvin
    Search for a thread started by BeirBrennerE30. He did a good write-up on this a while back.
    If you want to get rid of the transmission and ship it State-side, I know a guy who would be interested in purchasing it from you. He just mentioned today that he is looking for one.
        Past Car : E30 S50 6 Speed 5 Lug 3.73
        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
        ___________________________________________
        BNB Designs
        Engine Swaps, Fabrication, Innovation, General Repair
        Richmond CA
        Julian 848-248-8029
          http://www.r3vlimited.com/board/showthread.php?t=139206 :D
            Thanks guys! BTW I did try searching before but I got more info from u guys.
            I think I'm gonna do this as a Christmas project :)
              Is there any difference in installing the E46 six speed tranny vs the E36 M3.2 Evo tranny(the Getrag 226)?
              I ask because I have the the Getrag 226 from the Euro M3 evo.
                No difference other than the flywheel and clutch. The E46 tranny has a slightly bigger input shaft so you need a new flywheel, clutch and PP.
                  OP,
                  I am going to be doing a 6 speed swap as well. I have been looking into everything and i have gathered that you will need a euro shifter linkage, euro or custom tranny mount (provisions already in the chassis) an e46 clutch, the flywheel is the same. You could even get away with just swapping the clutch disc, if you have a recent or high perf clutch already. The Drive-shaft will have to be modded, you will have to have it shortened and balance...
                  The install seems pretty straight forward though...
                  Ryan
                  Turbo E30
                  Roadkill 80lb 93 octane OBDI tune
                  BavSol Cylinder Head
                  Stock S50 in. cam Schrick ex. cam
                  Otis' tubular T4 manifold
                  Oringed 87mm S52, Eagle rods and 8.5:1 CP pistons.
                  GT4094r w/Batmowheel Impeller
                  614whp@17.5psi, 100 Oct
                  690whp@21psi, 100 Oct
                  801whp@27psi, 110 URT
                  Old: 1/4 mile: 10.91@144.38 (636whp)
                  New: ?
                  http://www.youtube.com/watch?v=L_f7fUVqblI
                    What about the 6 speed tranny from the E90? from the 320i?
