EWS delete
  • Jonny Cash
    • 1763
    EWS delete
    My E36 M3 is still intact, I wanted to get the car running before I strip it down. Ive been trying to trace down the EWS issue with no luck. Basically, I have to fiure out what the previous guy did, before I can track down the original issue. Which has proven to be hard. Theres wires spliced in the main harness, all the ignition related wires uder the steering wheel were torn down and tampered with. I cant get ahold of the guy to ask what he did, or if he even knew what he was doing., it seems almost impossible to trace down.
    There's no fuel/no spark, the key battery is dead, and the motor wont turn. Fuel pump's good, coils are good. Im curious about the EWS delete, and exactly what it would do for me in this situation.
    Any help would be appreciated.
    -Jay
    2014 NASA FL se30 champ #81
    2001 se46 3 year plan in progress
  • matt
    • 3732
    What year is the car?
    • Jonny Cash
      • 1763
      Its a 95.
      -Jay
      • Jonny Cash
        • 1763
        Is this the wrong forum for tech stuff, or is this just not enough information?
        -Jay
        • surebimmer
          • Jan 2004
          • 978
          What's the part number of the DME? Does it have a sliver label and end in 506 or 413. Or Red label 413.
          • matt
            • 3732
            Jay, assuming your car has EWS (not all 95 M3s do) you just need to bypass the EWS starter lockout (cut the two large wires running to the EWS module and connect them together) and replace your chip with a non-EWS chip like the ones at www.racersmarket.net and your car should run fine.
            The only keys with batteries are the lighted ones BTW. EWS keys are powered by the antenna.
            • Jonny Cash
              • 1763
              Ill try that. I noticed it has a AOA chip also. On the female side of the plug there appears to be a few ports burnt out. Its a silver label 413
              -Jay
