24V oil temps
  • alexbaby88
    • 219
    24V oil temps
    For those of you with oil temp gauges, what temps are you seeing in:
    - hot stop-start traffic jams
    - On track
    - Highway cruising
    Thanks
  • erik325i
    • Jan 2005
    • 3567
    On Track, I was seeing about 200*F.
    This is with the Euro s50b32 plumbed up to an e28 m5 oil cooler.
    Erik
    • alexbaby88
      • 219
      Wow only 200 deg F? That works out to about 93 deg C which is what my temps arewhen the engine is warmed up in normal street driving. Of course my M50 has no oil cooler. I saw just over 120 deg C after 4-5 laps on the track.
      In heavy traffic on a hot day (ambient 35-40 deg C) it creeps up to nearly 100 deg C. Just wondering if this is normal for an M50.
      • asubimmer
        • 6482
        Should be around 190 on the track. Although a little warmer means thinner oil so less power loss. But that would be so small it would only be noticeable on a dyno.
        • erik325i
          • Jan 2005
          • 3567
          Now that I think about it, my oil temps may have been at 210 at the last track day. My oil system is definitely not stock though. I have approximately a 9.5L oil capacity.
          Here are two good threads to look over:
          Erik
          • dude8383
            • Jan 2005
            • 10387
            Erik
            wow thats an expensive oil change!
            glad that someone else but me was curious about the oil temps. i haven't had a chance to install my oil temp sensors.
            • matt
              • 3732
              It really depends on the oil you run. Dino will be toast at 260f, but synthetic will be OK.
              200-240 is about right for running hard with synthetic.
              • Mohammed_A
                • 344
                i just installed the oil temp gauge from the mz roadster, im using the e30 oil cooler on my s50 euro swap, im getting a reading of +- 80 deg celcius , but remember im still running my motor in so no hard driving...is the reading correct?
                • flyboyx
                  • 8371
                  i remember from one of my college automotive engineering classes my professor saying that as a rule of thumb, oil temp will in a healthy engine will normally be 40 degrees warmer than the water temp. by that standard, 80C seems a little bit low.
                  Gigitty Gigitty!!!!
                  • alexbaby88
                    • 219
                    So do you think its worth the effort for me to put in an oil cooler system for a car that is 99% street driven if I am seeing 100 deg C (210 deg F) on a hot day in heavy traffic? Would an oil cooler even make a noticeable difference to oil temps in traffic?
                    • flyboyx
                      • 8371
                      that sounds to me like a good operating temperature for engine oil to me. it needs to get to a certain temperature so moisture and gasoline vapors will evaporate from the crank case. what would be your purpose for getting the temperature lower than that?
                      Gigitty Gigitty!!!!
                      • alexbaby88
                        • 219
                        to avoid any chance of pinking and also the engine seems to feel more lethargic when temps are high.
                        I wonder why the M20 had an oil cooler and the M50 doesn't?
                        • Drew325is
                          • Oct 2004
                          • 520
                          M52B28 alloy block
                          7L oil capacity
                          M20 oil cooler
                          3-4 minute track sprint session at ambient temp ~15oC, oil temp tended to be about 95oC.
                          • pedal2metal
                            • Jun 2007
                            • 93
                            Answer: More oil capacity in the M50, hence lower temps.
