first start fail, wire melted, HELP
  • MattM
    • Apr 2009
    • 931
    Well, i went to try to start my engine today, it attempted to turn over once, then the starter started clicking like crazy, i pulled the key out and it was still clicking like crazy, i ran to the back and pulled the terminals off the battery. When i came back around front there was white smoke seeping out of the main harness(the big black casing) pulled it off and found a brown/yellow wire completely melted. It comes out of a green sleeve that connects afew other wires and heads down under the intake. I havent done anything in that box, so its all still factory. HELP!
    Full Build Thread Here
  • sharky
    • Jan 2005
    • 2672
    Dont know why you had the smoke but you have the two smaller starter wires on reversed so you are getting a constant instead of a switched via key signal, hopefully you didnt burn up the starter.
    • MattM
      • Apr 2009
      • 931
      i traced the melted wire and it was comming from the oil sensor, the starter didnt start to go until i hit the key, it just wouldnt stop when i pulled the key out.
      • Dominic49
        • Feb 2007
        • 1373
        oil preasure or oil level?
        you didnt attach your reverse light wires to the engine did you?
        • MattM
          • Apr 2009
          • 931
          got the car running yesterday, here is what i did,
          I for some reason thought that pin 1 on the engine side of the harness was oil level, which is wrong, pin 2 is oil level and pin 1 is 12v power for something(running off the starter circuit). So basically my starter was trying to suck the power to start it through the oil level sensor and a 14 gauge wire.... I cut my connection to pin one, and the car runs great, so i just need to hook it inot pin 2 and im all good!
          91 E34 525I btw
