Idle vibrations
  • Jim Lepage
    • Jul 2008
    • 1138
    Idle vibrations
    I have some vibration at idle (M50 at 600rpm). Could it be worn motor mounts ? It's also shaking while I release the clutch to start in 1st.
    My tranny mounts are brand new by the way.
    E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
  • jahnaboi
    • Oct 2006
    • 1742
    There's a lot of factors that could play a roll in transferring vibration to the chassis.
    What motor mounts? How is your exhaust mounted to the chassis? The motor is running fine correct?
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
    • Jim Lepage
      • Jul 2008
      • 1138
      -I bought the car swapped but the motor mounts look like e28 ones.
      -The exhaust is mounted with the bracket on the tranny and rubber mounts rear.
      -Yes the motor is running fine.
      • 416stroker
        • May 2008
        • 2448
        What do you have for a flywheel. Mine vibrates a lill I think its from having an 8lb flywheel.
        84 318I Delphin RIP
        87 325IS delphin 24v Sold
        89 325 Alpineweiss
        • Jim Lepage
          • Jul 2008
          • 1138
          I don't know what I have but it didn't do that since a lot of time. It started to vibrate on the highway at about 65/70 mph so I discovered that one of my tranny mounts were worn. I changed the 2 tranny mounts (took OEM ones) and now that's almost gone but it's vibrate at idle. Tomorrow I'll check my motor mounts to see if they're in good shape.
