M Coupe radiator
  • z31maniac
    • 17566
    M Coupe radiator
    Any problems using one? I'm guessing it will make the AC tough to keep?
    I'd like the extra capacity given our hot summers.
    www.gutenparts.com
  • lifeiskaos
    • 1709
    it'll work great. it's common for the e36 turbo guys to use this radiator, and and if it's plug and play in an e36, it is also in an e30
    • erik325i
      • Jan 2005
      • 3567
      I'm using the Euro e36 m3 evo radiator which is the same part the Mcoupe uses if I'm not mistaken. It works fine.
      There's no AC in my car, so I can't tell you about that.
      Erik
      • M-technik-3
        • 18946
        3 core design, seems robust and have never heard of Coupe owners complaining about them.
        • lowlightbw
          • Mar 2008
          • 668
          is it too large for the condesor? whats the problem with the AC?
          www.benjamineliward.com
          • z31maniac
            • 17566
            ^Thats what I want to know.
            www.gutenparts.com
            • windnsea00
              • 158
              The S54 radiator is 3-core, S52 was 2-core.
              Past: 1991 330is; 1995 318ti; 1993 325is; 1997 318ti; 1989 332is; 1999 Z3 M Coupe
              • lowlightbw
                • Mar 2008
                • 668
                anyone have one laying around they can test to see if the s54 radiator will work with an e30's AC? I may be replacing my radiator and would like to know.
                • flyboyx
                  • 8371
                  the s52 radiator will fit(barely) with the a/c compressor and there is no conflict with the condenser. there is only about 3/8" clearance between the front of the compressor and the cores. you can slide the radiator over to the passenger side as much as possible(assuming you have a post 87 car), and there will be about 1/4" or so clearance between the front edge of the compressor clutch and radiator tank on the right side. it is really tight, though. i think i am going to make a little sheet metal guard for my radiator to protect it in the event of a hard braking event. if the s54 radiator has another set of cores, i would assume it to be thicker. that being the case, i am going to have to say that there will be no space if you want a/c on your car. if i get a chance, i will post up a pic for you so you can get an idea how close it is.
                  i almost had an epiphany at the junk yard yesterday. i found a 525i e34 with an almost new radiator with integral tank. i pulled it out and compared it to a late style e30 but it was about 3 or 4 inches too wide. dammit! looks like i am going to end up using the late style e30 expansion tank on my car. i hate the way it looks and can scarcely afford to give up the space in that area of my engine compartment. i might look for an expansion tank from a v8 or v12 car that sits on the firewall above the engine.
                  Gigitty Gigitty!!!!
