Is M50 worth the hassle??
  • CrazyB
    • 420
    I am building a weekend track toy, and I was curious if it is worth going from m20 to m50, as the power rating difference from the 2 is not huge. Does the m50 take better to upgrades? Can I build a na powerful m50 for cheaper then the M20.
    As I do not have the money for the s50 but figured having a newer engine on the track would be nice, but curious if performance wise I will see a decent difference?
    AutoCross Photos!!https://picasaweb.google.com/eugenes18t
  • etxxz
    • Feb 2006
    • 2085
    there is a reasonable improvement considering how cheap you can get the engine and the potential it has over an m20... but imo s50 or s52 (even an m30) is where the swap is worth the effort.. you mention track. save your money for track time or invest elsewhere ie. suspension, seats, harness and maintenance. i'm glad i waited to buy the right gun.. once!
    No more e30s for me.
    88 black BMW OBDII 332is dedicated track [sold]
    88 BMW OBDII bronzit 332is [RIP 03/08]
    91 BMW 325i [sold]
    86 Corolla 'Ae86' HB 20v trd [sold]
    http://youtube.com/watch?v=pTj7Hn9v5Rs
    • Charlie
      kid tested, administrator approved
      • 6686
      M50 what? Vanos or non?
      Non-vanos motor, I wouldn't bother unless the M20 is dead. A vanos motor however makes for a nice upgrade. There's a lot more mid & low end power, and the motor is practically maintenence free. A chip alone nets you over 200 hp, and S50 cams are a pretty simple upgrade.
      -Charlie
      Swing wild, brake later, don't apologize.
      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
      FYYFF
      • M-technik-3
        • 18946
        Agree with Charlie. Can be done on a budget but don't skimp on important parts.
        • CrazyB
          • 420
          Not planning on skimping on parts that is why I don't think i can afford the S50.
          Only thing I am not sure of is is the transmissions. I don't think i want to keep my stock one as the whole idea of rotating it and bolts mismatching really does not sit right with me.
          But I was wondering if the m3 zf transmission will bolt up to a m50 and could I still use my original drive shaft?
          • namsayin
            • 1568
            the zf will bolt up to the m50 but you will need a m3 driveshaft.
            • balooshinakus
              • 511
              An s50 is about 1500 more, anything an s50 will need an m50 will need. A lot of the cost is in random stuff not the motor. I vote to save up a bit more.
              • bad_azz_bmr
                • Sep 2004
                • 433
                or a 328i auto drive shaft
                • jakeb
                  • 1909
                  I went with the m50 first....coming from a m42. And a year later I now have a s52 in it.....much more fun.
                  I got a decent price on a e34 m50 so it already had everything I needed. So my idea was to start there and then get a s52 and swap it all over in time. That time was less than a year later.
                  Save a bit more and get an s50/2 unless you get a great deal on an m50.
                  Now I have a spare m50 that I would like to find a e34 touring to build up with lots of added pressure......boost
                  www.classicdaily.net
                  1970 m42 swapped 2002
                  1985 LS1/T56 Swapped e28 (557e)
                  www.blunttech.com - For all your parts needs
                  Follow me on Instagram for constant build updates @classicdaily
                  https://www.facebook.com/ClassicDailyLLC
                  • mazur
                    • Jan 2006
                    • 731
                    I would say an M50 is a waste a time unless your going turbo. I've been in an M50 with every bolt on plus M3 cams and it still lacks a lot to match the power of an S50/S52. But it's technically all in the stroke of the crank. An M50 with an S52 crank would be awesome, but I don't know how cost effective that would be.
                    • etxxz
                      • Feb 2006
                      • 2085
                      91 BMW 325i [sold]
                      • shiboujin
                        • Feb 2006
                        • 2791
                        IMO M50s are good if your current motor is dead or lacks 2 cylinders. Course you could be one of the cool kids and boost one. I made ~270whp leaking badly pre turbo on 8 psi. M50B25NV 0.140" MLS gasket
                        • e30s50dan
                          • Nov 2008
                          • 2076
                          i ask myself this EVERYDAY !
                          NASA
                          BMWCCA member
                          PCA member 25yrs
                          1991 318IS slick top
                          1997 M3 sedan
                          2001 325CI DD
                          “whoever turns the wheel the least, wins"
                          • mazur
                            • Jan 2006
                            • 731
                            Ahh, fun times I presume ;)
                            • MR E30 325is
                              • Dec 2008
                              • 3300
                              I just picked up a NV M50, and I am stoked.
                              Sure an S50 would be nice, but M50's are so readily available, it is a logical stepping stone if you dont have deep pockets.
                              I definitely want to do S50 though, just need to find the right one.
                              My previous build (currently E30-less)
                              http://www.r3vlimited.com/board/showthread.php?t=170390
                              A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
