M52 Swap – Exhaust Sounds Like Crap
  • Boardhead
    • Jan 2008
    • 39
    I just got my M52 swap in my 90' vert on the road and it performs way better than I had expected. It really wants to RUN from 3500 rpm to redline! It is a blast taking it out on damp pavement here in Florida and intentionally spinning both rear wheels in first thru third gear with my 14" Basketweaves and skinny tires. However, I am really disappointed with the exhaust note. It sounds like a crappy four cylinder at anything above 3k rpm when under load (combination of raspy and load metallic noise). Here is my set-up; I am running ebay headers with dual 2” pipes to a dual-in-dual-out cat. From the cat I have dual 2” pipes necking-down to the dual ~1-3/4” dia. stock cat-back. The photo shows my home-made custom set-up. Excuse the poor welding, other than my rear sheetmetal repair, this is the first substantial MIG welding that I have tried.
    My objective is to keep the deep throaty sound that I have under 3K, all the way through the power band. Loud isn’t necessarily bad as long as it isn’t “buzzing”. I have searched this forum for others that have tried similar set-ups but haven’t found the right combination that builds on what I currently have. I am sure some of you guys have tried this setup and have found a sweet sounding solution. I appreciate your help!
  • jakeb
    • 1909
    I was running ebay headers when I first did my swap and yanked them fairly quickly.
    I had mine Y'ed into a single pipe and thought that was what was causing a lot of the rasp but I am pretty sure it is from the ebay headers..... The SS is thin and causes all sorts of noise.
    Maybe add a resonator after the cats.... or yank the ebay headers and get a pair of welded up obdII manifolds.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • Boardhead
      • Jan 2008
      • 39
      Thanks for the input. I was hoping I would not have to pull the ebay headers, but if that is what it takes… I think I will first try adding resonators as you suggested. Any recommendations on manufacturer/model?
      • Dominic49
        • Feb 2007
        • 1373
        i have my headers coated and it reallly cuts down on the rasp
        • e30polak
          • 6136
          Ebay headers are thin and tinny. That is a main cause of the rasp.
          INSTAGRAM: @UNDR8D_EMPIRE
          • Boardhead
            • Jan 2008
            • 39
            Is header thermal wrap effective in reducing rasp?
            • FredK
              • 14761
              Hey, that doesn't look half bad for a first exhaust! I couldn't even imagine doing a dual in dual out for my first exhaust.
              You should have seen my first MIG welded exhaust. The welds were lumpier than the mattress in a 29 dollar a night motel.
              • hugh jass
                • 2220
                you can really use any small universal muffler as a reasonator. that would be a cheaper option than yanking your headers.
                ______________________
                ex-Chief Operating Officer
                Blunt Tech Industries
                West Coast and Pacific Rim
                • e30this
                  • 3580
                  OBD2 headers welded and wrapped.
                  dual 2inch pipe into a dodge magnum converter. (its dual in 2 inch single out 2.5 inch)
                  2.5 inch all the way to a flowmaster 40 series muffler.
                  I have had about 4 different exhaust setups with my swaps and by far this is the best one yet.
                  • e30polak
                    • 6136
                    Here is my exhaust: eBay headers> y-pipe > 2.5" piping> generic Borla 2.5" muffler > 2.5" piping> 2.5" Vibrant Street Power muffler
                    It's all about the mufflers and resonators you use to compliment the headers. I made the rasp work to my benefit. :D
                    • e30s50dan
                      • Nov 2008
                      • 2076
                      are your headers wraped ?
                      NASA
                      BMWCCA member
                      PCA member 25yrs
                      1991 318IS slick top
                      1997 M3 sedan
                      2001 325CI DD
                      “whoever turns the wheel the least, wins"
                      • Wh33lhop
                        • 11705
                        To each his own.
                        paint sucks
                        • e30this
                          • 3580
                          Originally posted by Wh33lhop
                          To each his own.
                          Please explain, Maybe you like a shit load of rasp or sounding like a honda with a fart cannon on it.
                          • Wh33lhop
                            • 11705
                            Yes, I want my BMW to sound like a 4 banger. That's why I bought a 325i.
                            You will note I didn't talk down on you, merely stated my opinion. I like exhausts that don't drone. I am sure it's loud as fuck but it doesn't sound good to me, not really a fan of the lift-off snarl either. Inline 6s should sound smooth if you ask me.
                            Just my $.02.
                            paint sucks
