valve guides? what do I NEED to do?
  • shiboujin
    • Feb 2006
    • 2791
    I have a spare motor and want to build it to be hearty. I thought about new valve guides but don't you have to get new valves too? that easily becoems >$200 in just parts... What else should I do or is there a cheaper solution for guides?
  • AlarmedBread
    • Sep 2006
    • 1510
    guides need to be professionally installed.
    • shiboujin
      • Feb 2006
      • 2791
      I know. I'm having a shop do them. I wanted to know if I need to have them do valves and guides or can I get away with just guides.
      • FredK
        • 14761
        Now, take this with a grain of salt, as I am not a machinist, but I don't think you will need new valves.
        Usually a machine shop "reconditions" the valves, meaning they are cleaned thoroughly, and ground in certain areas. Prior to reconditioning, they will measure the stems to see if the stem to guide clearance will be within spec.
        • shiboujin
          • Feb 2006
          • 2791
          Yea I think that what I'm going to do. replace as necessary. If all but 1 guide is good, why replace them all?
          • jakeb
            • 1909
            You need to really have the valves checked before saying you need them or not.
            When I had an m10 head redone the head guy(all he does) said normally the exhaust valves need to be replaced because the heat of the exhaust burn the oil off the bottom part of the valve stem. Thus giving them more wear. I had to only replace the exhaust valves.
            www.classicdaily.net
            1970 m42 swapped 2002
            1985 LS1/T56 Swapped e28 (557e)
            www.blunttech.com - For all your parts needs
            Follow me on Instagram for constant build updates @classicdaily
            https://www.facebook.com/ClassicDailyLLC
