porsche 911 brake booster also works
  • got boost?
    • Jul 2006
    • 8
    Hey, I've gotten alot of good info for my swap so I figured I would contribute. From looking at a freind of mines porsche 911 I figured the brake booster from that would work so I grabbed one off of ebay with the master cylender and everything. So anyway do to a shipping error I didn't get it for three weeks. In the mean time I decided to go with a manual master cylender instead. I got the 911 booster in the mail this morning so I decided to see if it would work anyway. I found that it bolts right up to the firewall but the rod is about 1.75" too short. So I quick made a little extension out of some spare 1/8" bar. It was all out of an 82 Porsche 911sc. On the master cylender the outlets are on the same side and the same fitting size so you shouldn't have to make any new lines.
    here it is compared to a stock e30 booster
    heres you can see the extension I made
  • BMW_TUNER
    • Jul 2006
    • 1377
    Looks good it is a little smaller than a 944
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
    • got boost?
      • Jul 2006
      • 8
      What do ya know, I just checked to see if you could use the e30 master cylender and it bolts right up! The hole in the front and the rod are exactly the same!
      • dude8383
        • Jan 2005
        • 10387
        im curious about how well that extension works.
        there's no play in that?
        • got boost?
          • Jul 2006
          • 8
          none, after checking fitment I welded it to the boster rod.
          • vr4boy
            • 282
            wonder if that would work w/ a euro s50b32 swap i'm thinking about doing...hmmm
