wiring and hoses
  • MIKe30
    • Sep 2006
    • 2334
    Originally posted by FredK
    Exactly. Just attach the fusebox power cable to the positive terminal on the firewall, and you should be all set.
    The E30 starter cable must have been removed with the engine. It is just a fat cable that connects the battery terminal on the firewall to the hot lug on the starter.
    Does it happen to have the fitting on it that acts as a battery terminal connection... with the screw that tightens it around the fat piece of metal? if so, it DEFINATELY went... since I had to go to auto store to purchase a new termal connector gizmo.
    Sounds good though, all wired up. Just needs some grounds, the o2 sensors plugged in, and motor oil. then first start!
    Thanks again Freddy, you and erik are my hero's!
    • FredK
      • 14762
      Yes, it had the fitting that acted as a battery terminal connection. :mrgreen:
