m3 s50 life
  • veet
    • 33
    m3 s50 life
    Is 100k miles too much for an s50 engine? Comes out of an automatic 95 m3.
  • mbonder
    • 2255
    no
    • FredK
      • 14762
      Assuming it received reasonable maintenance, 100k miles is fine for an S50.
      Just make sure the retainers have been replaced if the engine has a production date of <10/95. The retainers (top spring plates) are a known failure point of earlier engines. If the valve collet pulls through, you'll drop a valve.
      I would do a compression or leakdown test just to see where you stand.
      • mbonder
        • 2255
        Always have to be more descriptive than me don't you Fred!
        • FredK
          • 14762
          haha, I figured a little more detail would be a little more reassuring. :mrgreen:
          In any case, even if the engine has a early production date, you can replace the upper spring plates, but this requires some specialized tools and know-how.
