FYI radiator alternative
  • redmist
    • Jul 2008
    • 26
    There is a 3" thick racing radiator ($230) made for asphalt modifieds that fits between the radiator support posts where the a/c fan/radiator goes (went).
    I used one and made my own fan shroud from 16 guage SS. Enables the use of the OEM fan. Also has the advantage, because of it's size and outlet placement, of being able to utilize very short (and simple) radiator hoses.
    DD -1991 318is panda
    time travel vehicle - 1987 stupid light e30 2.9 m50/m52 all alum, rear H1E turbo
  • static
    • Oct 2005
    • 501
    can you take some pics? cheers
    • Teaguer
      • Sep 2004
      • 6167
      Suffern' succotash. Haha. :p
      Now back to the rads ....theres no need to cobble up a domestic or circle track rad .
      These Mishimoto's are perfect fitment for our cars and tested by many E36 & S14 owners already :
      An ideal upgrade for the brittle stock BMW radiator, the Mishimoto E30/E36 Performance Aluminum Radiator provides your vehicle with enhanced reliability and improved cooling efficiency. BMWs are known to have frequent cooling-related failures due to the use of numerous plastic components throughout the system. A simple coolant leak can result in overheating, accelerated engine wear, or head gasket failure. Whether you have a daily-driven E36 M3 or an M20 spinning a large turbocharger, this E30 and E36 radiator provides ideal temperatures on and off the track. Most people overlook the importance of installing an upgraded radiator in their vehicle. Along with providing increased coolant capacity, this BMW radiator improves heat dissipation, which is beneficial for both stock and modified applications.The Mishimoto E30/E36 Performance Aluminum Radiator is manufactured using durable aircraft-quality aluminum end tanks, precision TIG-welded to an efficient brazed aluminum core. The inlet and outlets provide precise leak-free connections, and all factory overflow and temperature sensor ports are present on the Mishimoto E30 and E36 radiator for use with stock sensors and hoses. This BMW radiator also includes a M12 x 1.5 Magnetic Oil Drain Plug with Dowty seal, which effectively removes metal fragments circulating in the cooling system. The Mishimoto BMW Performance Aluminum Radiator incorporates mounting points for the factory external automatic transmission cooler, and it is a direct bolt-on fit for all 6-cylinder E30/E36 models from 1988 to 1991. As with all our BMW parts, this aluminum BMW radiator includes the Mishimoto Lifetime Warranty, ensuring superior product quality and craftsmanship.
      They can be found on eBay for $236 shipped.
      (although I have a source to get get them for $205 shipped) ;)
      • e30this
        • 3580
        And we have group buys where we can get them for 190 shipped.
        Has ended as of now. Should be starting a new one in a few weeks..
        • Teaguer
          • Sep 2004
          • 6167
          Meh, I never travel over to emotech. Plus some homo banned me anyway. :roll:
          • e30this
            • 3580
            No one said you had to go to emotech. Group buy was listed on Bimmerforums and a few other places as well.
            • Teaguer
              • Sep 2004
              • 6167
              Well you listed a link to emothech.....so what do I know ? :roll:
              I was aware that there has been Bf.c GB's though.
              • z31maniac
                • 17566
                I bought an S54 MCoupe radiator to use in my swap, I'll see how it works out in a few more weeks.
                www.gutenparts.com
                • redmist
                  • Jul 2008
                  • 26
                  You guys are missing the point. This radiator fits in the a/c condensor fan area eliminating clearance issues when using the mechanical fan. Hell I can get a radiator for $140 to fit where the old one resides.....
                  • lifeiskaos
                    • 1709
                    where's that damn smiley...
                    edit: ahh, here it is:
                    • dude8383
                      • Jan 2005
                      • 10387
                      this is only good for the people that choose to delete their a/c systems completely.
                      that being said, driving in the rain with 90% humidity with windows rolled up SUCKS DONKEY BALLS.
                      • Teaguer
                        • Sep 2004
                        • 6167
                        Yes exactly.
                        I noticed that you mentioned that it fits in the condensor area ....but that means no more a/c.
                        That to many, including myself, is a huge compromise.
                        • rThor432
                          • Feb 2007
                          • 3907
                          Well, I wan to see some pictures. I dont need or want A/C on my E30 (Thank God for NC's weather) and a radiator that fits where my condenser was and is just as effective sounds excellent... Let's see it.
                          • 5KWattson
                            • Apr 2009
                            • 809
                            Edit: Ahh, here it is:
                            +2
                            "God created turbo lag to give V8's a chance" Taylor D.
                            • redmist
                              • Jul 2008
                              • 26
                              Pics tomorrow. You can still use your a/c condensor and fan, there is still room for it but you would have to alter the mounting.
