So went to try and start my S50 for the first time.
Cranks like mad but here is what is going on.
Main power relay is working.
The fuel pump relay does not kick on the pump and can be manualy grounded. It has 12 constant and 12V switched and the wire from Pin #1 DME shows 10.5 volts.
The Coils show 12v switched but no pulse
The Injectors are not opening. No fuel on he pugs even with the Relay hot wired.
The DME is a Red Label 413 with a TRM chip. I also cut wire 66 just in case. The DME shows power on some ports so it is getting power.
It sounds like EWS but I have no EWS.
Help. I will update as I do further diagnostic tests.
