Crank Case Ventilaion
    Ok Im getting oil in my elbow from the PCV. I know m3s with S52 have something to filter the oil out. Will just changing the pcv fix it or should i go to catch can set up of some sort.
    I wish i could just delete the pcv and run a breather.
    I Have no blowby,great compression &I Bun no oil.
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
    Try the PCV valve first it can't be more than what, $8 bucks?
    Transaction Feedback!
      ya but the pcv is straight threw theres nothing in it to keep the oil out. I dont think it fix it I wanna know whats a common fix?
      84 318I Delphin RIP
      89 325 Alpineweiss
        what kind of valve cover are you running? ive never examined the underside of the valve cover on my s52 but i have noticed on obd1 aluminum valve covers there is a baffle around the breather port. perhaps to better block the oil from spilling out because the obd1 engines dont have the oil seperator setup like obd2s do
          Its a n/v motor ill have to look at that. I just changed my valve cover gasket maybe i fucked somerhing up under there.
          Im just gonna weld up a catch and see if it fixes it.
          84 318I Delphin RIP
          89 325 Alpineweiss
