Driveshaft Woes and Wonders???????????
  • bmw320e21
    • Jan 2005
    • 67
    I had a e90 come in for harsh vibration under wot and it turned out to be heat spots on the flywheel. You might wanna check that out too.
    Adam
    • jahnaboi
      • Oct 2006
      • 1742
      Its all figured out. Thanks.
      SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
      • Jason89i
        • Sep 2004
        • 875
        sssooooo. what was it?
        • D-rock
          • 714
          My car did the same thing...
          • jahnaboi
            • Oct 2006
            • 1742
            Was the flex disk. Had hairline cracks on it that were not visible at a resting position. Only noticeable if you put two bolts in two holes and pulled them apart acting as if there was load put upon it (like how it is on the car).
            • MIKe30
              • Sep 2006
              • 2334
              sheesh, thats frustrating. glad you found it though.
              • jahnaboi
                • Oct 2006
                • 1742
                Seriously... very frustrating. I only figured it out because I saw that my painted selector rod had the paint stripped at a certain point from where the flex disk under load was expanding and rubbing against it.
