Wats up i got a e30 im puttin a s50 in complete motor trans i have the diff also but i was told to use a 3.25 ive been searching and looking for vids but can really get an answer. Im lookin to do good numbers on the highway bassically w/e she can push and im not looking to get launched on off the line.. i was told a 3.46 is good but not sure on wat it gives u off the line and in top gear.. and secondly why cant i use the 95 e36 m3 diff isnt it a 3.46 also?
Which diff should i use?
Tags: None
get a 3.25 i bought one from BOBY and i love it on a highway u top out about 145 148 and i raced with my friends e36m3 he was in a 4th and i was in 5th and it looked like he was standing still. its verru torquesigpicComment
Only the auto-magic cars had that diff. The diff wont physically mount in your car, but iirc you can swap the ring/pinion/carrier into an E30 case.
What engine do you have? Did the car run into the great wall of aerodynamics at 145, or did you run out of revs?Comment
The 3.46 diff will be faster in every respect, but will have a lower top speed, rev higher on the highway, and cause you to shift earlier.
I used to have the 3.25 with my s52+ZF set-up, and it was a great ratio. However, the 3.46 made the car accelerate faster in each gear. I will never go back! :woowoo:Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
What engine do you have? Did the car run into the great wall of aerodynamics at 145, or did you run out of revs?[/quote]
its an s52 and i ran out of revssigpicComment
Well ive seen the 3.25 on youtube and looks like it gets about wat u guys say is there another diff that can pull 155 out of 5th n not b a slug in 1stComment
Pretty close, 3.73*.805 = 3:1
My old car with stock 195/65/14 would pull to 6800-6900 with a 260 and 3.73, very slight uphill. Would not pull to 7100. I'm sure it would've pulled to redline on flat ground.
Dads old car with a 1:1 gearbox and 3.46 would pull 7500 in 5th. It may have had a little more.
With an overdrive 'box, I'd use a 3.73 or 3.91 with a 2.8 or greater motor. With a short-stroke 2.5, I'd use a 3.91 or 4.10.
The 1:1 gearbox is a blast with a 3.45 but 5th gear is way high on the revs.
since we're on this subject, i as well am in the middle of an M50 swap out of a 92 325is (no-vanos) i am using the Getrag 250 tranny and driveshaft from the 325is...I had a deposit on a 3.25 from the Euro Depot and they sold it out from under me so i ended up going with a 3.73.....only thing they had left in an LSD.....will this setup be ok?Need Custom spacers and adapters?
PM for informationComment
When are we running!?The 3.46 diff will be faster in every respect, but will have a lower top speed, rev higher on the highway, and cause you to shift earlier.
SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]Comment
does anyone have a "Master list" of what diff's came out of which cars year/model/manual or auto ..i can then go to the junkyardsNASA
BMWCCA member
PCA member 25yrs
1991 318IS slick top
1997 M3 sedan
2001 325CI DD
“whoever turns the wheel the least, wins"Comment
