firewall/harness grommet
  • Lof8
    • Oct 2006
    • 2827
    I had to tear the shiz out of my old one to get the m20 harness out. I'm having a hard time finding the part#. anyone know?
    thanks
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
  • flyboyx
    • 8371
    even if you do, how will you get in on over the ecu plug? i suggest getting one from a junk yard. i had to slit mine up the side to get it off my m42 harness. i plan to put that edge down and fill it with urethane.
    Gigitty Gigitty!!!!
    • rThor432
      • Feb 2007
      • 3907
      Remove all of the pins from the connector, slide the grommet over, and re-assemble the connector .
      I thought it would stretch enough to get over the connector, but it's been a while since I've messed with it.
      • BMW_TUNER
        • Jul 2006
        • 1386
        I got mine over the conector with the connector partialy disassembled. The only problem now is getting it to seat back in the fire wall. I
        1989 332IS -S-Fiddy Four-Some weight removed.
        5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
        • Lof8
          • Oct 2006
          • 2827
          I will probably put a slit in it to get it back over the harness. The one I removed is unusable. pn?
          S50'd
          • 325Projectz
            • Jan 2005
            • 1956
            i found an m42 harness at the junk yard, cut it right at the grommet got it off in one piece, and with enough monkey fucking and some ass lube (silicone spray) i got it over the s50 ecu plug and in the firewall without ripping or cutting.
            91 m3
            • jahnaboi
              • Oct 2006
              • 1742
              If you really are having trouble, just get a blade and cut it directly down the middle. Position it in the firewall and use zipties (two) to make it air tight. Its the easiest and most effective way without wasting much effort and time. Plus it seals.
              SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
              • AlarmedBread
                • Sep 2006
                • 1510
                You can remove the black plastic cover w/ clasp on it from the ecu plug, then it is a lot easier to get off/on.
                • e30s50dan
                  • Nov 2008
                  • 2076
                  my M50 harness has a square grommet, and the 318chassis has a round hole..did you guys square the hole or cut off the square grommet to the harness,and taped ths shit out of it???
                  NASA
                  BMWCCA member
                  PCA member 25yrs
                  1991 318IS slick top
                  1997 M3 sedan
                  2001 325CI DD
                  “whoever turns the wheel the least, wins"
                  • Lof8
                    • Oct 2006
                    • 2827
                    anyone know where to get a new one or have a part number??
                    S50'd
                    • rThor432
                      • Feb 2007
                      • 3907
                      ^^I think that's what I did..
                      • M3 euro ltw
                        Site Sponsor
                        • 259
                        Part numbers
                        I recently spent an incredible amount of time trying to track down part numbers and such regarding the rubber boots on and in and around the harness box and such.
                        It can be very frustrating.
                        If you examine the grommet closely, and can find a part number on it, it is very likely to be just the 7 digit version.
                        In the E36 section, usually, its 12 52 in front of that if I recall....but check on realoem.com to see what some of the other similar parts are labeled, and it might give you a clue to the front 4 digits.
                        Why?
                        Well, because in my recent experience, the dealer was no help. BUT...give the guys at Maximillian Import a call, and ask them to check on the part number you want. INSTANT results virtually, and they're a pleasure to work with.
                        Good luck!
                        If there is no part number on the grommet, you may well be SOL. I assume you've tried REALOEM.com.... Many parts are considered to be part of an engine harness, and not available independently. Very frustrating. But you may well find that some other car model has something similar that will do, and can be ordered.
                        Trying to make the world a better place, 6 TB at a time.
                        http://abloriginalparts.com/
