Break booster request.
    i have a e21 brake booster and was wondering if anyone here, that is running the same booster could post up some before and after pics.
    Thanks
    -Rob
    Need Custom spacers and adapters?
    PM for information
    ill break your booster at your request
      way to be a dick...If you read the the thread it is very clear that i know how to spell BRAKE booster, it was meant as a joke...as in im taking a break from this booster. Thanks for your oh so informative help!! +1 for Mr. knowledge
      PM for information
        I've heard that it requires slightly more pedal assist to stop compared to a stock e30 booster setup.
        SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
          Ya i mean i'm not worried about that so much as i am modifying it properly. That way even though it will require more pedal assistance it will work at ITS best potential.
          PM for information
            i just measured how long i needed it, and cut it. i then grinded the shaft to a slightly smaller diameter and threaded it. turned the fork on til it was the same lenth as the factory one and insatalled. i have no pics though, but its very easy to do.
              Mine's a 325ix booster but the idea is the same.
                if it was a "joke" then you shouldnt be so offended by mine Mr. Sourpuss
                  thanks for the bump buddy
                  PM for information
                    this is what i did...
                    let me know if you have more questions about it. i thought it was much better then grinding down the rod like the other people are doing....
                    91 e30 318is M50 SOLD
                    http://www.r3vlimited.com/board/showthread.php?t=149570
                    92 325 vert project
                    http://www.r3vlimited.com/board/showthread.php?t=341370
