Trying to finish swap - Driveshaft Problem
  • g22
    • 274
    I’m swapping in an M50 into a ’89 325i. I’m using the G260 trans and I thought that I was supposed to use the same drive shaft that was originally in the car. Obviously from the pictures it’s way too short, about a full inch. What am I doing wrong or missing?
  • mazur
    • Jan 2006
    • 731
    I have heard of certain stock E30 driveshafts working with the swap, but it usually comes down to needing either a 96+ E36 driveshaft or the E30 M3 driveshaft, whether you use the stock tranny or the E36 tranny.
    My friend ran into this issue with his swap and the stock Getrag. He ended up taking his driveshaft to a shop to have modified to fit.
    • g22
      • 274
      Really, that's the first i heard. I read through ALL of the swap thread and most say match the trans with the driveshaft that came together. Thanks
      • RedTRex
        • Dec 2008
        • 249
        No that won't work (obviously), you need 1/2 and 1/2 of e36 and e30 , just don't recall which is which ------- search as the info is in here.
        I have read that in a few places but here's one....
        Leave now before I shed my human form and kill you
        • lennon
          • Jun 2008
          • 1416
          for what its worth, ive seen several 24v swaps use getrag 260s and original driveshaft. i dont know what you did different to end up with the trans further forward, but its definitely not all swaps.
          • e30Rob
            Master of Adaptation
            • 1182
            i'm using the G250 out of a 92 325is with entire driveshaft from the donor and a 3.73 diff....what diff are you running?
            Need Custom spacers and adapters?
            PM for information
            • g22
              • 274
              I'm using the g260 and driveshaft from my '89 325i.
              • namsayin
                • 1568
                87e30 just did this with his swap and the driveshaft bolted up fine with the tranny. weirddd
                • 318isbmw
                  • Nov 2005
                  • 2841
                  Have you tried loosening up the nut in the center and pulling the driveshaft out of the slip yoke?
                  • 416stroker
                    • May 2008
                    • 2448
                    Mine worked as well with a stock drive shaft
                    84 318I Delphin RIP
                    87 325IS delphin 24v Sold
                    89 325 Alpineweiss
                    • e30s50dan
                      • Nov 2008
                      • 2076
                      agree...........,try the CB.there is a little room,just not sure an inch!
                      NASA
                      BMWCCA member
                      PCA member 25yrs
                      1991 318IS slick top
                      1997 M3 sedan
                      2001 325CI DD
                      “whoever turns the wheel the least, wins"
                      • D-rock
                        • 714
                        With my car they had to build me a custom drive shaft. b
                        • M-technik-3
                          • 18946
                          I just assembled one using the stock 260 and the driveshaft that came out of the car with no issues. Granted mine is a 87 325i 4 door. Not that should make a difference.
                          • g22
                            • 274
                            I was able to lengthen the driveshaft to fit. Thanks for the help.
                            • learningcurve86
                              • May 2008
                              • 715
                              there's a surprising amount of telescoping-action to these driveshafts. kind of surprised me. glad to hear you found a no-cost solution :)
                              Greg
