Tunnel Heat Shielding/Sound Deading
  • Spaz
    Crazy Canuck
    • 2276
    Just trying to figure out my heat shielding situation, did you guys remove all the heat shields/rubberish heat shielding on the firewall/tunnel?
    If you did, did you put in self adhesive heatshield mat?
    Just curious as to what you guys did.
    -Cam
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
  • jahnaboi
    • Oct 2006
    • 1742
    I kept it all. Saw no need to remove something that didn't interfere with anything.
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
    • 1990m3
      • 1180
      kept all mine for a long while but removed it when it turned to a track car. my passengers complain of a hot footwell so I'm going to put some metal sticky heat reflective stuff in there soon to see if there is an improvement.
      • M-technik-3
        • 18946
        Removed every last bit of the crumbling mess. Just keeps sand salt and mosture near the body which promotes RUST. Plus the extra noise is fll raze you know....
        The conversion to a 24v in last few cars has been quieter than the M20's with the crude in place anyway.
        • sharky
          • Jan 2005
          • 2672
          I removed all of mine as it was deterioration and nasty, cleaned it all up and bought some thermo tec acoustic and heat barrier and am going to do the whole firewall and tunnel with it, pretty nice stuff and probably took atleast 10 lbs off the car doing it.
          • mattdk318i
            • Jun 2006
            • 3953
            I removed mine because it was nasty too. Bought some stuff from Summit Racing. It was thermo something.
            I installed it from the firewall all the way down to the end of the trans tunnel. Makes a huge difference in sound and heat in the car.
            • rThor432
              • Feb 2007
              • 3907
              "Anything that doesnt make it go faster is only adding weight." I took it out. Havent had any issues or complaints worth mentioning.
              • e30s52
                • Oct 2007
                • 5235
                +1 it also makes easyer to get the tranny out. I left mine in the first time and I could get to the top of bell housing so I had to drop the front subframe down to get to it.
                www.gutenparts.com
                • rThor432
                  • Feb 2007
                  • 3907
                  Good point, didnt think of that. It does make getting at the bolts a breeze.
                  • xLegendOZWest
                    • Jan 2009
                    • 406
                    mines all gone. felt no reason for it. lost weight =) feels a tad warm but its fine
                    Live Fast. Drive Faster.
                    "Nitrous is like a hot girl with an STD... :)
                    You wanna hit it, but your afraid of the consequences :(
                    • e30_325es
                      • 1249
                      How did you guys take it off the blower motor cover? Seems to be completely glued on?
                      • justin_l_
                        • Jun 2007
                        • 1079
                        I took it off mine with a heat gun and a scraper on my first swap. Shaved it nice and smooth, painted it and realized that I needed it to mount my wiring harness cover. Needless to say I haven't bothered with it on any of my other swaps.
                        • apexhead
                          • 32
                          I removed the portion that was blocking the upper transmission bolts. It just made it easier to install / remove the transmission. I also used a heat gun to scrape off the insulation on the blower motor cover but didn't take off the mounts for the wiring harness cover. The majority of the insulation on the firewall is still there.
