Thought I had everything ready...
  • 87e30
    • Jul 2008
    • 5676
    I plugged in the battery... and POP!
    I heard a loud pop and the battery sparked. The fuses all look good...
    What did I do / how does this happen?
    I have the fuse box wired DIRECTLY to the power from the battery and I do NOT have the motor grounded yet. (no oil yet either, not that that matters)
    I'm kinda freaking out, I'm a complete noob at this stuff and thought I finally got it sorted out. Guess I fucked something up.
    Background: swapping in an m52 w/ getrag 260 and e36 auto harness obd2 wiring. (wired in the ews tonight)
    I just hate everyone.
    No need for discretion.
  • Jean
    • 18228
    What else is hooked up to the battery.... you should have a ground on the engine before hooking it up anyway as otherwise starter/engine ground will go through the engine harness/fusebox.... unless it finds another way.
    • e30Rob
      Master of Adaptation
      • 1182
      uuuuh did you say it was NOT grounded? may i ask why not? you've checked all the fuses and everything?
      Need Custom spacers and adapters?
      PM for information
      • jonmon6691
        • Aug 2009
        • 252
        Did the pop come from the battery? Are you sure it wasn't an arc as the wire got close? I've seen batteries arc when re-connecting them, its normal.
        <-- F*** that guy
        • 87e30
          • Jul 2008
          • 5676
          All fuses look fine.
          Just added a ground to the motor.
          Upon further investigation the ECU was burnt/fried right where it was grounded. (e36 ecu doesn't fit in the eta bracket so it was kind of twisted in there as a temporary thing and it was barely grounded)
          Car IS in the air not touching the ground... that might be a stupid nooby comment though.
          • lennon
            • Jun 2008
            • 1416
            thats not your problem.
              • 37833
              ECU ground doesn't matter, car jacked up doesn't matter.
              Good luck man.
              Grover Beach, California
              BimmerHeads.com
              • 87e30
                • Jul 2008
                • 5676
                Okay, I figured it was a stupid statement. I'm a noob and took grounding literally...
                Give me a break please... I want this shit to work!
                So ECU ground has nothing to do with why their was a short right on the ECU and it burned?
                I should just look around the area and see if anything is touching?
                • Jean
                  • 18228
                  Yeah, sorry ground as in Negative wires.... inspect all your wiring connections and verify you don't have a positive wire going to Negative etc...
                  • mazur
                    • Jan 2006
                    • 731
                    Just to make sure, you are using the original OBDII DME?
                    • 87e30
                      • Jul 2008
                      • 5676
                      The only things I hooked up were positive wires as I hooked up the e36 harness to the power supply. (bought a harness adapter)
                      I didn't see any major grounds coming out of the e36 harness. (Am I missing something)
                      Only ground I saw was near the air pump (obd2 stuff)
                      Yes, engine and DME came from the same parts car.
                      • 318isbmw
                        • Nov 2005
                        • 2843
                        Sounds like you've got a positive connected to negative to me.
                        • 87e30
                          • Jul 2008
                          • 5676
                          The only thing that confuses me is this:
                          The e30 fuse box has two red wires coming off of it, but they are different sizes. So I just connected both of the to the power supply. Everything I hooked up to the power supply was a red wire.
                          By power supply I mean the main battery cable coming into the engine bay, I just bought a round plug from shucks that I had screws in it where I put the power wires
                          • Jean
                            • 18228
                            Take some pictures and post them. Engine harness should have both Postive (usually red) and negative (usually brown) ends on it.
                            • 87e30
                              • Jul 2008
                              • 5676
                              Hmm fuck... I must have missed the engine harness ground. I will go hunt for it. I assume that would just go to the frame with the rest of the grounds.
                              It's pretty dark and I do'nt know how helpful pictures would be as it just looks like a complete mess of wires all attached to a battery terminal thingy on the power line.
                              OFf to hunt. Thanks for the help guys, really appreciate this. I'm still confused how I heard a massive pop and can't find a blown fuse.
