Finally got it started and took it for a drive, problems.
  • 87e30
    • Jul 2008
    • 5676
    Okay, so messing aroudn with the fuse power box does nothing.
    Why have I popped 8 fuses? gahhhhh.
    I just hate everyone.
    No need for discretion.
    • MIKe30
      • Sep 2006
      • 2334
      there's a short somewhere bud. what a pain in the ass. Who did your harness?
      • gazellebeigem3
        • Jun 2005
        • 3712
        Originally posted by e30s52
        Try a slightly larger fuse.
        no.
        yeah, i would make sure that the adapter is wired correctly and make sure that a wire isnt pinched somewhere and grounding out.
        • 87e30
          • Jul 2008
          • 5676
          It looks like it's time to dive into the harness.
          The tach isn't working either, which points towards the harness.
          • BMW_TUNER
            • Jul 2006
            • 1386
            The two wires that go towards the fuse box are not both hot. One is hot and the other is ground. Start there. Strip back the two big black wires going towards the fuse box, one is a ground for the entire harness. That's probably the issue.
            1989 332IS -S-Fiddy Four-Some weight removed.
            5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
            • Aatos
              • Mar 2008
              • 43
              Only one hot wire goes to fuse box from battery/started and it attaches underneath the PCB. Open the fusebox (it's only lid + two screws in the panel) and you'll see how it works.
              • White325is
                • Oct 2006
                • 5947
                like I told you on AIM you need to check the wiring. Even though you bought an adapter. People make mistakes. Go back through and check it.
                • gazellebeigem3
                  • Jun 2005
                  • 3712
                  hahahaha you should be banned from any tech section
