Let's say I don't care about using the A/C switch (which I don't) and just want to wire the fan to a switch inside the car that will work with or without a switched lead/temp sensor etc, just "ON/OFF".
I can just bypass all the relay bullshit and give it a power and ground, and ground the signal when the switch "closes" correct?
If yes, would you still use the big stock power lead, or grab a power source from say the block the starter wire hooks to on the passenger side?
