twin mass flywheel ?
  • e30 blue
    • 69
    Can someone tell me if all e36 5 speed trannys can with a( twin mass flywheel) ? I have one, but not sure I want to use it.Thanks up front for any help. Real oem shows twin mass . The machine shop needs a flywheel to put the engine back together and all i have is this( boat anchor) twin mass flywheel.
    • 37833
    Yes they had a dual mass. I'd recommend ditching it for an aftermarket single mass. You can get a brand new steel one on ebay for roughly $200.
    Grover Beach, California
    BimmerHeads.com
    • flyboyx
      • 8371
      i used my dual mass fly from my mz3 donor car. i like it just fine. it had the largest clutch surface area available. it is lighter (slightly) than the stock m20 single mass that i have. provides a nice dampening effect when i dump the clutch. also you don't have to get the back side custom machined to clear the oil pan. in my opinion, if you have it, use it. you will be happy with it unless you are racing. in that case, go spend the 6 hundred bucks and buy an aluminum lightweight.
      Gigitty Gigitty!!!!
        • 37833
        ^ I just said there is a single mass made for the E36 in steel for about $200 new...
        BimmerHeads.com
        • e30 blue
          • 69
          Thanks Mr 325 , I have spent so much on the rebuild thus far, Not sure im down for a new just yet .The shop said they could shave it down for me, so this is my best option for now.
          • erik325i
            • Jan 2005
            • 3567
            I've neve heard of a machine shop being able to shave down a dual mass flywheel.
            • e30 blue
              • 69
              Thanks flyboyx as well for the info, I am going to use it.
                • 37833
                Agreed. Nobody will even resurface a dual mass, let alone lighten it.
                BimmerHeads.com
                • e30 blue
                  • 69
                  Okay good to know that's not going to happen. I think the machine shop has not seen the twin mass flywheel for some time now, Why cant you rework a twin mass? Is it because there is no way to turn it ?
                    • 37833
                    http://cgi.ebay.com/ebaymotors/F1-RA...Q5fAccessories
                    BimmerHeads.com
                    • e30 blue
                      • 69
                      Thanks again Mr 325, That F1 look's great, I have spent too much on this motor in the last few weeks. I will have to wait untill more work starts up and brings the $$$ back home .
                      • asubimmer
                        • 6482
                        Thats the 240mm flywheel! The stock e30/e36 325 setup is 228mm. The OP didn't say what size he had but I would assume 228mm.
                        • evil_twin
                          • Nov 2007
                          • 2965
                          I'm using the F1 flywheel with their 6-puck clutch and pressure plate. I couldn't be happier :)
                          Paypal: vdang5@gmail.com
                          Delta Auto Care
                          2875-C Towerview Road
                          Herndon, VA
                          703.435.1375
                          My Feedback Thread: Evil_Twin
