throttle cable questions.
  • LowR3V'in
    • 4209
    Hello.
    I was wondering if the m3 cable was longer or short then
    the 325i cable. Same?
    Thinking it's the same since it's basically the same engine.
    Just double checking.
  • Dominic49
    • Feb 2007
    • 1373
    why does it matter? you need an e34m50tu cable
    • tonytony
      Knee deep in poopie
      • Jan 2004
      • 3498
      you dont need it, it's just one of those anal things people do. I used my stock 325i cable and it works just fine, you do need to make a spacer for the extra length though, where the cable meets the TB
      • omar85
        • 331
        my e34 m50 throttle cable is too short. idk why. just fyi
        • rThor432
          • Feb 2007
          • 3907
          I bent a bracket to take the slack up. I've got the right cable, but because the stock one works, I havent ever gotten around to installing it.
          • mazur
            • Jan 2006
            • 731
            I used my stock E36 M3 throttle cable. I took up the slack by zip-tying the end of the cable down to a lower part of the bracket on the TB.
            After doing so, I noticed that I had perfect throttle movement from idle to WOT. Two years later, the zip-tie remains :)
            • 7pilot
              • 475
              I shaved some rubber from the fat stop grommet so that the adjust would be closer to the TB. Then adjusted the cable to get more slack.
              I would to do the same to an E36 M50 cable as it is identical in dimensions.
              m
