Hesitations at acceleration
    My M50TU has some hesitations (flat spots) at acceleration. It's happening when I start from idle to redline. If I start accelerating at high RPM it's not doing it.
    What could do that:
    -bad vanos unit ?
    -bad O2 sensor ?
    -bad crank sensor ?
    -bad cam sensor ?
    E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
    MAF sensor. They tend to take a shit.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
      -Charlie
      what he said. read the codes if you can.
      also check simple things like your spark plugs.
        Spark plugs and fuel filter are new. I'll check for the codes.
        EDIT: I'll try to clean the MAF ( http://forum.e46fanatics.com/showthread.php?t=335561 ) and search for cracked hoses (vacuum leak).
          I cleaned the MAF with caution with contact cleaner and it's now running very rough (vibrations) at idle and from idle to 2000 rpm. I don't see a big difference if the MAF is plugged or not and it's also smelling very bad.
          Do I need a new MAF ?
            ^^If there isnt a big difference between plugged in and unplugged, then it is very likely that your MAF is bad.
              Get a new one or test with a know good one.
              www.gutenparts.com
                Ok thanks for helping.
                  You can try back probing it to to see if the voltage is in specs.
                  www.gutenparts.com
                    If you need a MAF, I have a known working one that I could ship to you.
                    If you are interested, PM me.
                    1988 Bronzitbeige Metallic 325e 2-door S50 turbo (OO=( )=OO)
                    2008 VW Rabbit
                    1991 Audi 200 20vtq Wagon
                      PM'ed...
                        I'm at work and just received a MAF I found in a local scrapyard. My concern is the guy sent me a M52 MAF (Siemens 1 703 275). Will it work on my M50 ?
                          The m52 maf will be obd2 I think. I dont think it will work. Try realoem and compare part numbers.
                          www.gutenparts.com
