While i was going through the pin out for the bosch dme looking for the road speed signal input i came across a CHECK ENGINE LIGHT output on the dme.... out South African e30's dont have any check engine warning lights and was wondering if something could be hooked up to flash using this Output from the dme..
Does the dme throw out a signal if a fault is found.... road speed signal for instance then the light would flash?
