s50 need help!
  • M.R. Performance
    • Sep 2009
    • 49
    s50 need help!
    I have a e30 with aa s50 in it trying to pulll the head off but its wont budge all 14 head bolts are off the hole vanos unit with the timing chain n everything. headers off nothing left ,unless there a secret bolt i dont no of. Followd the direction from pelican. Any idea? PLEASE HELP lol thanks!
  • Van Westervelt
    • 9365
    As posted in your other thread...
    Originally posted by Van Westervelt
    There are two small torx bolts near the front holding the head to the timing cover. I bet you missed them.
    • M.R. Performance
      • Sep 2009
      • 49
      wat? to just keep searching?
      • Van Westervelt
        • 9365
        There are two small torx bolts on the front of the head connecting it to the timing cover.
        If you cant figure that out, then you need to give up now and kill yourself. :p
        • M.R. Performance
          • Sep 2009
          • 49
          wow wat a dick...thanks alot dude
          • Van Westervelt
            • 9365
            I told you what and where, 3 times. I cant really come out there and pull them off for you.
            "What" is spelled with an 'h.'
            • Wh33lhop
              • 11705
              He posted it not once but twice and you ignored his very helpful answer BOTH TIMES. Shut the hell up.
              paint sucks
              • justin_l_
                • Jun 2007
                • 1079
                lol
                • M.R. Performance
                  • Sep 2009
                  • 49
                  coool idc
                  • travis816
                    • 828
                    people like this guy should not own s50's.
                    88' m3
                    91' 318is
                    • e30_325es
                      • 1249
                      Actually he is wrong. There are 3 torx bolts holding the head to the timing cover. There are the two on the outside of the head. There is one other one holding a guide inbetween the cams.
                      • Van Westervelt
                        • 9365
                        That 'guide' should already be removed seeing as how he took the cams out already. And there are two bolts on the guide, one that goes all the way to the timing cover, and one that only goes into the head.
                        • SiGmA_X
                          • Mar 2006
                          • 287
                          What you said. OP should be polite and accept the help given, especially when Curt is 100% correct.
                          :wgaf:
                          PNW BMW Crew ///
                          '93 325iS
                          '99 528iT
                          • jrdeamicis
                            • Nov 2008
                            • 956
                            Wow, everyone is so helpful around here.
                            Past Car : E30 S50 6 Speed 5 Lug 3.73
                            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                            ___________________________________________
                            BNB Designs
                            Engine Swaps, Fabrication, Innovation, General Repair
                            Richmond CA
                            Julian 848-248-8029
