Another EWS delete question
  • matt
    • 3732
    Originally posted by Good & Tight
    Yes you do.
    What's on the other end of the wire?
    Regardless of what anyone at TRM told you, if you are putting your motor in an e30, there is nothing on the chassis for that wire to connect to, so you don't need to cut it.
    You don't connect it to anything at the C101 do you? (No.)
    • Good & Tight
      • Apr 2004
      • 2057
      Matt I have not spoken to TRM, I installed the 506 chip and was told to cut the #66 little green wire.
      Have not tried it yet, but I will try to start without cutting anything then see if the fuel pump turns on and etc...
      Your are right about not connecting anything to the C101, makes sense. I will post the results when I have it figured out.
      Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
      ____________________________
      E-mail Panayiotisx2@gmail.com
      Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
      • Good & Tight
        • Apr 2004
        • 2057
        O.k installed the ECU, did not cut any wires, the fuel pump turns on now while cranking. Did not have time to check for spark, will do that later.
        • Good & Tight
          • Apr 2004
          • 2057
          Well did some more testing and it is getting spark, but no fuel.
          this is what's going on
          pulled a coil and grounded the spark plug to the valve cover and plug
          fires while cranking.
          the fuel pump only turns on while cranking, pulled the plugs no gas on
          them at all after cranking over a dozen times.
          with a test light on the red wire of injector while cranking the light
          turns on does not flash, light will stay on a few second after key is
          turned off. will do the same if test light is put on brown wire of
          injector.
          Fuel feed from pump to front of rail and return on back of rail were
          regulator is.
          Sprayed some brake cleaner into intake and it fired right away.
          Something is not right with the injector wiring.....
          • peerless
            • 285
            injector.
            Ugh, I am in the early process of a S50 swap and the electrical is going to fun as it is a automatic harness that will need to be chopped up.
            In regards to the injector wiring and testing, the red wire is the positive side and the other is the negative side. Now that you know you have power to the injectors you need to test the ECM function. Put your test light on the negative side of the coil, it should flash indicating the coil driver is functioning properly.
            If it stays on solid or off then the ECM is not firing the coil(s).
            • Good & Tight
              • Apr 2004
              • 2057
              The coils are firing, the injectors are not. It's a problem with the chip, the tuner is burning me another one. Will have updates in a few days.
              • BigD
                • Jul 2006
                • 1085
                You did connect the injector ground to the lift bale right?
                • Good & Tight
                  • Apr 2004
                  • 2057
                  Yes. Got the new chip tonight, still no start, injectors or switching on and off confirmed this with the test light, still have spark, fuel pressure to the rail is good. Maybe the injectors are stuck from sitting a few months.
                  • jrdeamicis
                    • Nov 2008
                    • 956
                    Well if you are seeing spark the CPS signal is good (which in turn should get the injectors to fire)
                    I would pull the Rail out and crank and see really what its doing. Just because the test light is coming on isn't meaning too much.
                    Past Car : E30 S50 6 Speed 5 Lug 3.73
                    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                    ___________________________________________
                    BNB Designs
                    Engine Swaps, Fabrication, Innovation, General Repair
                    Richmond CA
                    Julian 848-248-8029
                    • Good & Tight
                      • Apr 2004
                      • 2057
                      Finally got it to start.
                      Pulled the rail w/injectors and they were spraying fuel. Then for some odd reason I lost spark and fuel. Swapped out the main relay and it fired right up.
                      But the main reason for this thread was to show that you need an EWS delete chip for the silver 413 ECU. No other way around it. No need to cut any wires either.
                      • turbo325i
                        • Mar 2008
                        • 1143
                        Good to know otis, as I am going to be getting my swap ready and will be needing to know this. Thanks!
                        Turbo e30 M52. Built Motor, GT3582r
                        Watch my vids http://www.youtube.com/user/GrudgeRider156?feature=mhum
                        • 5KWattson
                          • Apr 2009
                          • 809
                          i thought it was a red lable 413 that had the EWS delete or some thing...im about to start the swap and i got one for $40 so either way i can sell the bitch if its no use
                          "God created turbo lag to give V8's a chance" Taylor D.
                          • Uber E30
                            • 1409
                            Red has no EWS to delete, most silver's have EWS that basicly reqires you to get an aftermarket chip or a stock 506 chip to disable EWS.
                            -Alex
                            • 5KWattson
                              • Apr 2009
                              • 809
                              so to clarify...the red label 413 should start up and run with out a aftermarket chip correct?
                              • Uber E30
                                • 1409
                                yes, as well as a 506. Most silver 413's will need a chip though.
                                -Alex
