pin on diag. port info needed
  • e30Rob
    Master of Adaptation
    • 1182
    So i need to reset my oil service light and was told i can touch 2 pins together on the diagnostic port to rest the light....does anyone know what 2 pins this might be...i have enough lights on my dash this just adds to my frustration...lol
    Any help will be greatly appreciated.
    -Rob
    Need Custom spacers and adapters?
    PM for information
  • matt
    • 3731
    Depends on how you wired your harness.
    Did you connect the SI wires at the C101?
    • e30Rob
      • 1182
      i didnt wire it...Bought an engine harness adapter from Gregslow
      PM for information
      • flyboyx
        • 8371
        seems like with the late style diagnostic port, which i assume you must have, you can touch pin 7 to ground with the key in the accessory position. you can do a search for it on this forum and the other one. you will be able to find what you are looking for.
        Gigitty Gigitty!!!!
        • matt
          • 3731
          Only if the adapter wired it up correctly.
          • e30Rob
            • 1182
            the diag port is the one from the donor car which is a 92 NV out of a 325is
            PM for information
