Was shopping for an ETA but a local deal has popped up that fits the bill almost perfectly and it is decently clean. So excited at the prospect.
I want to do m52 or s52. I see Treehouse has the adapter or offer doing the swap for you. If you use the adapter what else is needed for a 'proper' swap? If I remember correctly when I was back working in shops you 'can' use the Getrag trans and 3.73 rear end but I seem to remember that is not the 'best' solution. A ZF trans is a better solution? If Getrag is used then you don't need to change anything in terms of driveshaft and such.
What else is going to be needed in terms of parts? Hope this goes through :)
